Mercruiser outdrive makes a clicking noise when you put it in gear (both forward & reverse). If you put it in forward and watch the prop it clicks and the prop moves slowly. Then it will all the sudden catch and work great. Same in reverse. Now with the engine off and the boat in forward gear you can turn the prop one direcrion, but not the other. In reverse you can turn it either way. HELP!!
