Clicking static noise is speakers when "off"
lenny2113
Hello, <br />I noticed that as my stereo is off and ignition is off, I get a static noise in all speakers.<br />What could this be? <br /><br />Thank you.
18rabbit
Re: Clicking static noise is speakers when "off"
Do you have a transducer onboard and is the sounder isolated?
lenny2113
18rabbit,<br />I have a Garmin fish finder with the trancducer...<br />Is this what you're asking?<br />Other electronic devices besides fish finder - VHF, Garmin GPS.
AndyL
Switch off your other electronics one by one until the noise stops. You will then know what is causing the problem. It should then just be a matter of moving that components associated wiring away from your stereo. Or it may be that if the unit responsible has some sort of internal oscillator / capacitor that you have to move that component away . If you have sufficient cable move the unit first as re-wiring can be a nightmare if the cabling is concealed behind fancy panels.
18rabbit
Sorry, Lenny. I mis-read your post. I thought I saw ‘clicking’, not ‘static’ in your post. If clicking, I would suspect the sounder. Andy has a good idea about switch each accessory on/off to find the source. And sometimes radio placement (relative to other radiating electronics) can make a difference in eliminating the static.
TexomaAv8r
Could be someone from the "otherside" trying to communicate with you......
lenny2113
TexomaAv8r,<br />I thought from time to time about learning "Morse code". I will now ;) <br /><br />Thanks to all
