If the motor has EVER run in salt water prior, no use putting a cooler on it now, the salt has already permeated the cast iron of the block and heads
If your motor has low fresh-water only hours, you can put a cooler on it, however you will need to flush out your block to get rid of all the sediment that is in there (and trust me, there is about at least a half pound of sand, rocks, and gravel sitting in your block currently.
you can look at San Juan Engineering for aftermarket kits, however after 7 years, I question if it would be of any value of benefit to your motor
