Closed cell foam for stringer core?
exp2000
I am thinking of following:
1. Cutting the tops of the stringer
2. Taking all the wood out, leaving glass in tact
3. Filling voids with a closed cell foam
4. Adding an 1'' thick wood at the top of the stringer so that floor can be screwed
4. Glass over the everything with epoxy so it would stick to previous poly glass
Does this sound like a good idea or is it stupid?
Re: Closed cell foam for stringer core?
Ayuh,... I guess it'll depend on whether it's an 8' Dingy, or an 80' Cruiser...
exp2000
Oh, it is 16 foot BL.
Bob_VT
bad idea........
You need the strength of the stringers. Regardless of the density of the foam it will not be strong enough.
Spinnaker
As long as you use core-cell foam. You can use core-cell in place of wood anywhere. Even better results if vacuum bagging. It is way much lighter and the strength is incredible. Pricey though. You would not have to glass wood into the top as core-cell will take screws. In fact, you don't need screws. Just weigh the floor down and use structural putty to adhere the floor to the stringers. With the floor glassed around the outside it's not coming up again.
I wouldn't leave the glass shell after removing the old wood from your stringers. You are just trying to save time and effort. You'll end up with air pockets unless you use a lot of structural putty and clamping, even then you're adding a lot of weight. It's just not the proper way of going about it to cut corners.
exp2000
Do I have to grind and remove all poly from the whole hull or can I just grind it like 6 inches on both sides of the stringer?
