Hello,
What I thought was an easy task to replace the oil seal and orings on the shift shaft has turned quite frustrating. The Bravo 3 drive is separated from the boat and I cant seem to get the shift cam to properly seat against the clutch (or so it seems). The cam seems to want to turn port side once the shaft is seated through. This means when I try to put the rear cover on, the spring as already cockeyed port side instead of straight on. This doesnt seem normal.
The cam will move left and right when it is free from drive but not when its back together. It doesn't looked damaged but I'm not an expert. Any help would be much appreciated. I've been googling and youtubing for days.
