Clutch dog
Where would I find a dog for a 1972 johnson seahorse 20 hp? I have been looking and cannot find anything.
Re: Clutch dog
You sure it's a '72? According to shop2.evinrude.com they didn't make a 20 HP engine in '72, but did have one in '73.
EDIT: I got momentarily stupid - they show a 20HP Johnson for '72 but not a 20 HP Rude. I shouldn't assume anything.
Re: Clutch dog
Believe it is, it says 20hp Johnson Seahorse (50th Anniversary). I will check the serial number when i get home.
kbait
Re: Clutch dog
Get motor model number and call Tim's outboard 218-682-2331.. they may have a good used, or quote for aftermarket. Did you check the forward/reverse mating surfaces?
F_R
Re: Clutch dog
There certainly was a 1972 20hp. Model 20R72R (20RL72R for long shaft). Clutch dog is part number 316501, replaced by 390030 dog and cradle assembly. They're not hard to find, just hard to pay for at a list price of $141.64. I have one left (new) for a lot less$$. Send me a PM if interested.
wilde1j
Re: Clutch dog
Fwd gear is usually NG as well. Sometimes, it's necessary to replace fwd, rev and the pinion as a set along with the dog.
F_R
Re: Clutch dog
If I was to replace the dog what else should I replace while I am doing it?
There just is no way to know what it needs without going in and examining it. And once you are in there, knowing what you are looking at. Most people will look at a worn out dog and gear and say it looks fine. It takes surprisingly little wear to make them jump.
