Cmc pt130 won't move
Ok so bought a boat with this on it. At first only the down button worked, up would not move or make noise. So I switched relays ect. No go.
Then I decided to change the oil, it was almost empty. That didn't fix it. So I pulled the top off of the motor part and the brushes were stuck. Put it back together after getting them cleaned up. Same problem. Then I pulled the bottom plate off, thinking the Piston was just binded up. Drained all the oil, pulled Piston completely out, put it back in. I had Piston filled extended and filled it back up with oil. Down button still makes noise but now it doesn't move at all. I turned pressure screw on bottom, pushed Piston up to two or three inches extended then tried again, still won't move.
Is there a certain way you have to fill this up or what? Why won't it move now?
Also when I put the screws in the black piece on top the motor when they are almost all the way down, as I finish screwing them in it pushes the black cap off, so I can't get the screws all the way down now???
