CMC Tilt Trim kit PT 130
miichael18
If i add the PT 130 tilt trim kit will everthing hook up the same as far as sterring cable goes? it says it shifts the motor away from the boat. i am replacing the steering cable so should i get a little longer one? the one i measured that was on the boat measures 15 ft 4 inches and its stuck in the middle so im guessing entended all the way out i would need a 16 ft cable? its a 16ft glastron v 163 with a 1989 125hp force.
racefan2
Re: CMC Tilt Trim kit PT 130
Yep it will just move the cable back 5 inches. I have the PT30 for the under 35 hp motors and it works very good so far but I have only used it 3 times. It does make a difference in the boat performance.
roscoe
I would bite the bullet and get a new unit.<br />ebay is ok for individual components, but many of the complete tnt units that age have problems, often expensive problems.<br />Parts for those old units are also hard to get.<br />I don't know if that particular unit will work on your motor.<br />The seller isn't even sure what it came off of.<br /><br />If your steering cable is on the short side now, get one a foot longer, because the cmc unit will set back an addition 5 to 6 inches.
