Bluestream
- Sep 28, 2010
- 296
A little background:
I bought this boat last fall with a broken engine coupler. At that time I changed the oil and the oil was black, but had no signs of water in the oil or the filter. PO said he was using it up until June when the coupler let go, and then he parked it and put it for sale. I put in new spark plugs and a fuel filter. Engine compression was 135, 130, 140, 140. Ran it on the hose for 15 mins and no water in oil. I then launched the boat and ran it for 25 mins. I then fogged the engine for storage, pulled in out of the water and drained the block and manifold, and stored it for the winter.
This spring I took it out of storage, and spilled a few gallons of water into the boat when taking the cover off, and noticed some milky oil in the bilge. I had cleaned the bilge spotless last fall. Checked dipstick, and the lever was up several inches over full (getting worried now
) Bottom of dipstick had rusty film on it. I put the drain plugs back in and started the engine and it ran fine for three mins. Checked dipstick and saw milkshake all over. (Getting very worried now
) I noticed there was milky oil running out on to the intake manifold right by the carb. I did not see when it was coming from, so I wiped it up.
I can only assume the water got into the oil when I ran it last fall. It is strange that there was no oil in the engine when I bought it. Possible that the PO had not used the boat last year as he told me, but the year before, then let it sit over winter not properly drained.
Any ideas where to start to trouble shoot this issue?
