cobra lower cable question
Bt Doctur
Re: cobra lower cable question
Depends on the corrosion factor
remove drive, gimbal housing , R/R/ cable,install drive ,check adjustments.
2-4 is my guess
danond
I agree. 2-4.
cr2k
You really need the special cable adjustment plate that goes on the bell housing. one to 2 hours.
bruceb58
there is a special plate but it does not go on the bell housing...it mounts to the pivot housing
180shabah
Wherever the plate goes, you must get thee adjustment correct ro you will need a new drive.
bandit86
Banned
thanks, just wanted to see if I want to get into it. I already have the outdrive off, and the manual in the sticky section didnt cover the process as thoroughly as I would have wanted
bruceb58
The manual in the sticky section is the Seloc manual and really sucks when it comes to the shift cable. You really need the OEM manual for the shift cable.
This will also help you
http://www.hastings.org/~stuart/cobra/
Gary H NC
What year is it? I have a friend who has some of the original manuals.
bandit86
Banned
87 bayliner. I had it for 3 years now, most things I know from experience but not i/o drives
danond
You don't want to learn from experience on an I/O drive. It will cost you more than it's worth.
Get an OMC service manual and follow the instructions. Not a SELOC. Not a Clymers.
You do not need the plate to adjust the cable. You can use Stuart Hasting's website instructions and they work great. My drive shifts perfectly and I use his method.
It's not magic, rocket science or even difficult. It's just tedious. Adjust it properly and your drive will last a long, long time. Get impatient and guess, and your drive will go "boom".
Limited-Time
I just completed the lower shift cable replacement on a 91 Cobra powered by a 3.0 Liter HO. No special tool used. Just followed the instructions found here. There is a section that refers to a pre-special tool procedure to accomplish the correct settings. They worked well for me. Shifts like a dream.
bandit86
Banned
thanks for the link. I dont think mine takes 2 pounds of pressure, worked well last year when i lubed the cable with graphite cable lubricant. the part in the outdrive seems hard to push up and down, definately mote than 2 pounds
danond
Use a fish scale on the cable. You can't measure 1 or 2 pounds with your hand.
You also didn't say "I followed the manual" or "I read the website and did it that way" which tells me you guessed. That means your cable is adjusted incorrectly, plain and simple.
bandit86
Banned
no I didn't use a fish scale, I don't own one. I didn't follow the manual, I searched for as much info as I could find. The cable is probably, make that more then likely adjusted incorrectly. I had a problem shifting into reverse last year last run, when I checked the cable my (class A) mechanics mind is telling me the cable is too stiff, which is why I want to change it anyway and start from scratch. I did check my local library but didnt find an omc manual, though to save my outdrive I'd rather invest in a OMC manual. I'd like to remove the cable so I can measure it up so I can order the manual, cable and all other parts I need at once, maybe save on shipping.
incidentally, will this manual cover my 87 5.7Lcobra ?
http://www.iboats.com/OMC_Inboard_S...9424453--**********.531034374--view_id.438189
danond
That manual is for a 1977. You can find the one you need on eBay.
For example: check this link
You don't need to measure the one you have, you just need the part number.
Part number: 987661 check this link (ebay)
I'm making big assumptions here so make sure all the stuff I've linked to is exactly the parts you need.
You need a fish scale to do this right. Don't guess.
bandit86
Banned
thanks for the reply, I sent him a message
once the sun comes up, I'll look for a part number
the shifter rod inthe drive, the one the cable moves up and down, how easy should that move? mine seems to be pretty stiff
