k is there a way water can get into the lower outdrive unit if i may have messed the gasket up between the outdrive and the back of the boat? Im not sure where water is getting in, but i checked my fluid after taking it out for the first time and there is water in the gear oil. Ive just replaced the lower portion of the outdrive last weekend and i know the upper was still good, but when i was putting it on i think i may have messed the gasket up between the upper and rear mounting spot on the boat. Where else could water be finding a way in? the o rings between the lower and upper omc cobra unit? Im kinda still learing about these so be patient... lol.. Thanks and the boat is a 88 4.3l sunbird with omc cobra outdrive.
