Cobra pinion gear
deepdiver17
Hi, I've taken apart my 5.7 Cobra Drive. My question is the lower pinion gear. I've taken off the pinion nut however I can't get the pinion gear off the lower drive shaft. I've tried gently prying with a long screw driver with no luck. Does anyone know a simpler way with breaking out the blow torch.
vinney
Re: Cobra pinion gear
Put the pinion nut flush with the end of the drive shaft. Then Take the prop shaft and hit it toward the top of the cavation plate. I use my hand with a fast pop. It works every time. Then remove the nut and pull the drive shaft out.
