Re: cobra sx trim cylinders are leaking down after a short period
There are several areas that can cause this and you've eliminated a couple of them saying you have no external leaks. It is now then an internal leak from with-in the pump, likely the trim up check valve or an internal leak from an unseated impact valve or bad piston rings in either of your trim cyls. I would bring the drive all the way up and mark the resevor/check your fluid level. Let it sit and bleed down. If the resevor level is up, problem is in the pump (check valve). Level the same, fluid is by-passing with-in the trim cycl. There is a seal kit available to replace all seals and piston rings but if the problem is a bad impact valve contained in the piston, you'll have to replace the cyl. If you get a manual, it will show you a break down of the pump and where the check valves are. There is no repair procedure for the trim cyl themselves so most just replace them but there are many threads here on the forum that address how to do it and have the part number for the seal kit.
