I have a OMC 3.0L with cobra outdrive 1988. the trim does not make a sound when I use the controls on the throttle, not even a sound.
So I jumped the solinod and nothing happened. I disconnected the wireing harness from the trim unit and ran it straight to the battery. Nothing happened, so I tappd the motor with a hammer and now it goes up and down when I wire it straight to the battery. It still does nothing when I plug the harness back up and try to use the controls. My question is this. There is a 50 amp fuse and 2 solinods is this all there is to check or is there a relay or two?
