Code 14 Coolant Temperature Sensor for mercruiser 7.4 mpi
BigDog98
I need help finding the Coolant Temperature Sensor. I got the motor scanned and code 14 came up witch is Coolant Temperature Sensor. I can find a regular temp sensor but not a Coolant Temperature Sensor. My engine serial # is OL085399. And also a diagram on how to replace it would be good too or video / picture. Thank you
thumpar
A serial number would help but it should be in the thermostat housing.
cdiamond
temperature sender operates a temp gauge
temperature " sensor" is an input to the ECM
completely seperate
unless you have a smartcraft gauge - which will display temp sensor readings
BigDog98
completely seperate
Don't really understand , on the seatrial the temp gauge was working as should. Why is it showing a code then? I was told that the coolant temp sensor just helps the engine idle when cold and warms up faster. Can someone please send me a link to the exact that i need to make sure I order the correct one please. Thank You
Fun Times
Merc part number 805218T. It looks like these, http://www.bing.com/images/search?q=805218T&FORM=HDRSC2
It should have a yellow wire going to it since it's part of the fuel injection system and not the temp gauge.
http://www.crowleymarine.com/mercury-outboard/2705.cfm?mdl=TVT6XQ&q=OL085399
Item number 11,
