Coil locating ring
harp2822
Anyone have the o.d and i.d measurements for it? What years does it fit?
Fit many models from 1950 to at least 1990.----I have the ring but do not have the I. D. measurement.
davidmbv
Google “Richard’s Outboard tools”. He sells them and lists the dimensions on his webpage I believe.
oldboat1
Mount the coils absolutely flush on the mounting posts. You should be able to run your fingernail down the laminated mounting surfaces without feeling any variation. If you follow that procedure, you should not need a ring.
