ok very new to boating, but experienced in mechanics for 25 years. So i bought my first boat, the previous owner removed the exhaust manafolds, Risers, the thermostat housings and painted them. In the process he removed the plugs. Not a smart idea. And had the starter rebuilt. But did not put anything back together. Sorry this is an 81 mercruiser 260.
started to put the boat back together, I found out that the thermostat housing for cracked so I just ordered new ones then I installed the starter and tryed to turn the motor over with the plugs still out which consequently living on the West Coast of Florida condensation had built up in the cylinders and blew the water out. that starter lasted for less than two days. So I purchased a new starter then I found out I had to rebuild a carburetor. so I Polled the carburetor off and rebuilt it. oh yes I also had to replace the slave solenoid.
now when I try to start it, I get the initial 12 volts off the slave solenoid, to get spark to the coil but the minute I let off the key I lose all power to the coil. please if somebody out there has some good wiring diagrams or advice as to where I should be getting power from to power up the coil I would greatly appreciate it
