porkchop85
- Sep 19, 2016
- 8
Good morning I have a 1983 SeaOX 230c with the 470. I hope to make this as readable as possible. The engine has a new cap, rotor, plugs, plug wires, points replaced with pertronix2 though on the water I installed a pertronix 1(see below) (stator replaced with alternator) 4 inch exchanger, new elbow, new carb, electric fuel pump.
Yesterday after about 30 minutes of running the engine sputtered and shut off. Boat did this last year so I replaced the 3 ohm flamethrower with 1.5 flamethrower. Same symptoms sputters and shut off. On the water replaced pertronix 2 with a pertonix 1 as I carried it as a spare. Wouldnt start with ether to rule out fuel. Boat will start and run fantastic once it cools off.
Am I over heating my coil? It has direct 12v with no resistor wire per the instructions. I was reading 14.5 volts with no electrical load and 13.8 volts with an electrical load(bilge fan). Should I ballast the coil so that it does not get the full 14 volts from the alternator?
