i just changed the boats thermostat because it was over heating. it would run for about 2-3 min. then would bog down then just shut down. i took the cover of and try to touch the top of the engine but it was way to hot to even get close. so i changed the thermostat and took it out again. got to about the same place on the lake and about 2-3 min. of running time and the engine did the same thing. but the engine wasnt hot at all. so i was wondering if it could be the coil that needs to be replaced also. or how to check to see if the coil is bad. i need help and will take any advice thanks for looking.,:facepalm:
