Can someone please give me test procedures to make sure the correct voltage is going to the coil under running conditions?
I am on my 3rd coil in 3 years. Every summer since 2017 I have replaced the coil in late July or August. Same symptoms.. Boat runs fine for 40 minutes then all kinds of power problems. I replace the coil and the problems disappear for 1 year.
The points are good. Plugs are good. The Dwell is fine as well as the timing. What could be ruining the coil the past 3 years. I've never had this problem before. I've had the boat since 1992. Its a 1984 2.5 L OMC.
Thank you
Thank you
