coil, stator, cd, and tigger id question
philly5eagle
Long story short I have the electronics from a force motor and I am trying to figure out what year they came off of. They were going to be the replacement electronics for a sport jet I have but it wasn't going to work out.
Now I'm looking to sell them but I'm trying to figure out what exactly what I have.
I have blue coils but no #'s on them. Is there a part # associated with them and what is it? From what I have been reading they are identified as blue coils and work with a number of years. I read the part # for all blue coils may be F684475. Is that correct?
I read something similar regarding the cd modules (proper name?).I can't find a part # on them either. Is a blue module interchangeable with all units that use a blue one? And a possible part # of F685301. Is that correct?
Trigger is a Prestolite. I can't find a part # on it. Where would the part # be located? The year of these parts I believe to be somewhere around 1990 and off of a 90 hp but I'm not sure.
Stator has a # of FCC3007C 428. Any ideas what motor and year etc that would work with? If so it may help me narrow this stuff down.
Thanks
roscoe
Re: coil, stator, cd, and tigger id question
Yes, all blue coils are interchangeable.
And all blue cd modules are interchangeable.
I think some people has successfully intermixed blue and black, but I'm not sure.
Since the wiring still uses a terminal strip, it originally came from a 1991E model, or earlier. So it came off a 1990-1991E motor.
Nordin
The coils and CDI modules will fit all Force 50-150Hp 1988-92 maybe with some modifications due to the connectors. Some have fastconnectors and some terminalstrip.
The stator and trigger will fit all three cyl. Force engines 1988-1992.
jerryjerry05
The stator will fit 85/125.
The setup according to the stator wiring color, is probably the early ones.87/88/89 somewhere along then89/90 they changed the wire colors on the stator.
The fast connectors were before 87.They were a BIG problem and were changed to the terminal strip.
I will fit 86-90s
philly5eagle
Thank you to all of you that replied. I really appreciate the info. That helps clear a few things up. Hopefully this will help others in the future as well.
If anyone else has anything to contribute on this, it will be appreciated as well.
