coil to "M"
guywithboat
I have a positive white w/red stripe wire that comes from the coil. Should this be connected to one of the "M" terminals on the ignition switch, or the ACC terminal?
DHPMARINE
Re: coil to
Re: coil to
That color wire doesn't ring clear in an OMC/BRP harness.What motor do you have ?
DHP
guywithboat
Re: coil to
Re: coil to
Guess that would of helped...
1967 Johnson 60hp 4 cylinder.
