coils
NHGuy
Hi there. Longtime no post. How is every one?
So, I had some trouble starting my engine at the end of last season and ended up winterizing it without a good start.
Some of you may recall i built this engine over the winter leading up to the 2016 season.
It's a 383 with 1997 Mercruiser Alpha 1 gen II ignition, controls and drive.
Last week I noticed that my OE 1997 TB V coil had leaked oil while stored horizontally off the engine. That OE coil had been removed and stored while I tried (and failed) a new never used Sierra coil I had bought for my previous 1987 TB IV engine.
This past week it got up to 50 degrees and I had a chance to do some testing.
I printed the TB V test flowchart and checked the gray tach wire at the coil, it was not grounded. So that's good.
With key on the coil + terminal showed 11.38 volts when my battery had 12.4 volts. That's a possible issue.
Then my spark tester arrived in the mail.
When I cranked the engine with a starter button and key on, the spark tester lit on #1, I got an orange flash. That's a possible issue. I'd expect a brighter flash with a good battery.
Then I did a leakdown test and got 7 to 10% at all 8 holes. So that's good.
I had the distributor out last fall too.
I wonder if I have the engine mis timed. I have done that before.
I have watched the valves on #1 come to a close as the timing mark comes to the indicator. I believe that is correct, but I've goofed on it before.
The first time I every stabbed a distributor I got it 180 degrees off. So anything is possible.
I may have to go back to restart my process to find the error of my ways.
Ayuh,.... Welcome back,.... I'm gonna go with corrosion, or generally poor connections,....
Start at the battery terminals, 'n Clean yer way to the ignition,....
Both the Positive, 'n Ground connections,... 'n both ends of all the cables/ wires,...
by clean, shiny enough to eat with. when done, use marine electrical varnish to seal the connections.
