Cold start ETEC
muskytroller
I have a 2004 75 ETEC and it has started to stall when the engine is cold. It will always start and if I bring up the RPMs it will run ok.
Once the engine warms up a bit the problem is gone.
At all RPMs it runs strong.
Is there a cold sensor or something that needs to be cleaned?
Silvertip
Re: Cold start ETEC
If the temp sensor is the issue it is not because it needs to be cleaned. Those are resistance elements and they either work or they don't. They change resistance based on water temp.
boobie
Re: Cold start ETEC
You may want to have a laptop computer put on it and see if you have any codes. Also when starting you can see what's going on.
