Cold telltale 3 cylinder loopers
Chun-Mu
I've read a lot of posts on the telltale remaining cold after extended runs or long idle.<br /><br />It is my understanding that these 3 cylinder loopers have the telltale tapped before the water circulates through the engine. Therefore the water temperature is ALWAYS cold.<br /><br />If this is true the only thing you monitor with our telltale is the proper functioning of the impeller/pump. And would recommend tapping a pressure/temp gauge on these engines to ensure proper cooling of the powerhead.<br /><br />Please give your thoughts and or comments on abovementioned….
Texasmark
Re: Cold telltale 3 cylinder loopers
I agree with your initial assumptions. I had a stuck closed thermostat on a 90 hp '02 and the telltale was strong as ever.<br /><br />Mark
