confused Ron
- Jan 26, 2009
- 1
i have been working on this boat four years now the wiring harness is there but no gages theres a 10 gage orange wire that goes to alternator and theres a 10 gage red goes to starter blk grd i put new oil pressure sender old one was warning lights also water tempurature sender same this boat has electric shift need help wiring questions which wires go where starting at the ignition its three tab battery/ignition/starter need help with these gages amp/fuel/oil pressure/water temp/rpm tach/ mph i have a fuse pannel and ground strip i have the lights/blower/bildge on their own switches they work also wired in the gage lights with light switch i dont have a trim pump only tilt and also ballist resister this boat was a project ive painted it had stern drive done professionally the boat ran years ago so i know engine is OK ? this boat is a 18ft tri/hull waterski/fish thats it i have omc manual but my wiring isnt diagram for gages etc thanks for your time was in motorcycle accident year ago haven't worked very little fundage or i would have mechanic work on it
