Colored rivits bayliner
Bvc
How do you remove the colored rivets that hold the plastic covers on the rear corner of my Bayliner Capri boat the one cover has a vent for the air pump the other corner just looks like fresh air in
Woodonglass
I'd recommend a hammer and sharp chisel. Use stainless steel screws to put it back on.
AShipShow
I literally just removed these from my boat... they are plastic rivets that are non removable. I used a flat head screw driver to pry the head up till they broke off and then pulled the center pin up with pliers and then the whole thing pops out...
looks like mcmaster sells the same ones to use as a replacement or use screws as wood suggested.
