Comp. Test
Bryan76
Got a 4.3 gm out of a truck done compression check the other day 180 all the way across except for 170 is that high it has dome top pistons in it now the boat is popping at wot pull back to about 3/4 it runs fine?
Re: Comp. Test
Ayuh,... She's runnin' Lean,... You have a Fuel Issue...
probably the carb...
