Re: Compatability
Oops! My bad! The early 60 hp was either a 1970 or 71. For some reason I had 65 on the brain. You can bolt it to the boat but youll have to use the controls for that year. That was a hydro-electric shift.<br /><br />If it were mine I'd rebuild the 92. Probably the block is boreable and the crank and rods are OK. The middle cylinder, most likely, got scored from the motor running lean in the mid range. So yes -- it will happen again if you dont correct that situation. Not that uncommon on the 56 cid motors.
