complete parts list of SX-M bellow & u-joint service - can't find pivot drawing
blurry
Hi there. The bellows on my 03 SX-M 1.79 need to be replaced. Other than oil, the out drive hasn't had anything done to it in a long time so i would like to replace wear parts and seals within reason. I've been looking at drawings and threads on here to get a parts list - I'm unable to find the pivot assembly - sounds like there might be thrust washers in there that should be replaced.
anyone know where I can find the pivot drawing? any other recommend parts or service? how do I see if the anodes need to be replaced?
thanks!!!
here are the parts I have so far:
tools:
bearing puller
bearing installer
drive shaft allignment tool
stand for outboard
1/2" hex bit
confirmed:
u-joint: SPICER# 5-1306X Ref: https://forums.iboats.com/forum/eng...outdrives/244162-u-joint-part-number?t=238091
There are three upper housing drawings, these parts are the same on each http://www.volvopentastore.com/Uppe...on_id.073290321--store_id.366--view_id.782024
water passage seal part #29: 3852560
new nuts part#28: 3853329
there are four bearing carrier drawings (Rockwell and GKN) – not sure of the difference, parts below are the same for both http://www.volvopentastore.com/Bear...on_id.073290321--store_id.366--view_id.782027
drive shaft o-rings (2) part #9 3852565 replaced by 997368
gimbal bearing seal part#11: 3852272
gimbal bearing part#12 3850853 replaced by 183247
gimbal bearing o-ring part#16: 925095 replaced by 967344
misc:
propeller shaft grease: 828250
unconfirmed:
u-joint bellow (volvo): 23075752
exhaust bellow (volvo): 3850426
pivot housing????
thrust washer (2): 3852697
thrust washer (2): 3852558
o-ring (1) 983513
kdiddle
I'm pretty certain I can't list the URL here due to site rules, but gonna try anyway...this site has wonderful schematics and allow you to look up every part on your engine/drive/housing..
blurry
thank you - link worked, unfortunately the pivot housing isn't listed. I'm still finding multiple bellows part numbers, I was hopeful that the pivot housing would confirm the bellow part number.
blurry
perfect, thank you! Looks lide there is an early and a lte version of the transom shield. only difference if the hose washer so I'm going to order both.
updated list:
tools:
bearing puller
bearing installer
stand for outboard
1/2" hex bit
parts:
u-joint: SPICER# 5-1306X Ref: https://forums.iboats.com/forum/engi...umber?t=238091
pivot housing early version:http://www.volvopentastore.com/Gimb...on_id.940318186--store_id.366--view_id.789339
pivot housing later version: http://www.volvopentastore.com/Gimb...on_id.940318186--store_id.366--view_id.789340
u-joint Bellows Kit: 3841481 (also 3854127 in some places) Replaced by 22197130 replaced by 23075752
exhaust bellow: 3850426
exhaust bellow clamp: 3852603
washer (2) 3852697
washer (2) 3852558
o-ring (1) LATE: 983513
o-ring (1) EARLY: 3852535
There are three upper housing drawings, these parts are the same on each http://www.volvopentastore.com/Upper...view_id.782024
there are four bearing carrier drawings (Rockwell and GKN) – not sure of the difference, parts below are the same for both http://www.volvopentastore.com/Beari...view_id.782027
misc:
bruceb58
My boat is a 98 and I still haven't replaced the exhaust bellows. Really no need unless they are ripped. Even then, it's just a little noise until you get it out of the water again.
blurry
hmmm... so I confirmed this is an "early" edition based on the o-rings I purchased, so that is good.
I did manage to order the wrong u-joints, gimbal bearing and seal - first time missing that many parts, no biggie plenty of time!
U-joints - I have outer clips - BTW the camden inners are a paint to press with the curved surfaces, I had to cut arcs in a piece of metal piping to get the inside supported so i could press out the u-joints. Looks like Volvo used two types of u-joints - for folks that find this pull the shaft first and see if you have inside or outside clips. I have outer clips which have a different part number:https://forums.iboats.com/forum/eng...-volvo-penta-sx-m-u-joint-spider-part-numbers I got lucky and found 2 NOS on ebay 3860232 OMC COBRA
Seal - this thing is a bear to get out - three jaw slide hammer wouldn't touch it. had to hammer the lip out and use locking pliers to bend it a little. at that point I was able to use the slide hammer with the seal lip adapter while holding a 2x4 for pressure - nice backyard style work :) ordered part Sierra 18-8349
for the gimbal bearing pretty sure I got it right this time - sierra greasable: Sierra 18-2100
