Complete Rebuild of 1972 StarCraft SS
L2attler
1972 Starcraft SS Rebuild
16' with a 65 hp Mercury.
I bought the boat on 7/25 and began working immediately.
I will be posting pictures to track my progress.
My goal is to completely rebuild this boat from the ground up.
This is how I bought it.
This is the end of day 1. Took most of the bolt on items such as rod holders ect.
Ripped up part of the floor to find that the plywood underneath was untreated water logged and rotten.
Day 2: Finished ripping out the interior. Had to drill out half the bolts necause the heads fell off the screws as I tried braking them loose. Took off windshields, steering wheel and the rest of the floor. Began cleaning the inside aluminum.
What has been done so far:
Boat has been stripped.
Old paint has been completely taken off to the bare aluminum.
Engine is off the boat, tested and in good condition.
Aluminum has been sanded, waiting to order the paint and that can begin.
In Progress:
Floors have been cut out, currently soaking them in teak oil.
Transom has been cut out, waiting to be treated.
Making a new dashboard, out of red oak and Poplar.
Plans for the side panels, designs are laid out.
Pictures will be posted in throughout the thread, as I get something done, I will post detailed pictures. If you have any questions, ask away.
GA_Boater
Re: Complete Rebuild of 1972 StarCraft SS
Welcome L2. You are in the right place for help on your SS. I'm still looking for my tinny, but the folks here are great. The Resto-Pros will take care of you and give you great advice.
You 're off to a good start. I can't officially enroll you in the Starmada since I'm not a member yet, I can say you are now addicted! You will be smelling Gluvit and Rustoleum in no time. If you get frustrated, sit on a box about where the helm will be and make motorboat sounds. I think it helps! I do it in front of my PC. LOL
Bighoss
Nice! another SS in the fleet! Congrats and welcome. I think to be anointed one of the Four Fathers have to give the blessing. I'm pretty sure it'll be just a formality. Pics and all in the first post probably sealed it.
ezmobee
Wow you didn't waste any time! Nice hull and good work on the tear out. Now would be a good time to apply Gluvit to all the rivets and seams from the inside. Good insurance against future leaks.
Paint is up to you. Good old Rustoleum works great on these boats, or you could step up to a two part marine paint. I'm a big fan of my marine vinyl floor http://i176.photobucket.com/albums/w200/ezmobee/New Boat/DSCF2504.jpg
Woodonglass
I'm a BIG fan of Rustoleum paint, Especially if you use the Acrylic Enamel Hardener. Check out page #10 in my rebuild thread for the forumula and how to apply. For Tin Boats you MUST use Self Etching Primer and then I recommend two thin coats of Rustoleums Bare Metal Primer and then 2-3 three thin coats of the Finish Color Coat.
Check out this guys results.
http://forums.iboats.com/showthread.php?t=309879&page=23
Jayb123
Welcome...WOW ...... you went straight to business :D. good luck.
L2attler
Yeah, I definitely jumped in right away.
Fun fact: this is my first boat. This is my first time even working on a boat ( I'm 21 yrs old ) hopefully going to make this boat so it can last me for a good while.
As for the floors I am going to go with marine vinyl. Probably a light gray.
Huron Angler
Nautolex shark is a nice light grey marine vinyl. I used it on my SS and have been very happy with it. Very durable.
Welcome aboard L2:)
L2attler
That's looking pretty good. Do most people use brushes/rollers or air brushes for aluminum boats? I was planning on just laying down thin coats with an air brush
ezmobee
We're probably about 50/50 on rolled vs. sprayed.
showmecb
Nice boat, I have been following the starcraft projects for a while now and have yet to come up with any leads on a supersport. Hopefully my day is coming. I will be watching your progress closely.
Jayb123
Personally... If i could do mine again I would spray... more work up front... but I think it looks a little better in the end :D
L2attler
Started stripping the paint. Original primer, red factory color, gold, and gray. I'm getting it down to the bare aluminum. Pictures coming tonight
jasoutside
Well look at that! Another Starcraft, welcome!
Like raining alum boats around here:)
L2attler
Into the night. It is aluminum after all, just have to get through 5 layers of paint
Woodonglass
Check out the link in my signature for a link on how to post your pics
Jayb123
man at your rate you'll be splashed and Ill still be applying my 2nd coat of epoxy :D. Well done sir... love the bare alum :D
MichaelP
Man you are just ATTACKING that paint. Your making us old timers look bad. Is that a steam cleaner, whats your process? Oh...Whats the cooler for?:D Is your secret weopen inside?
L2attler
Im just using an industrial power washer. 240 degrees not sure the pressure, but safe to say it's alot.
And the cooler is for sitting have a herniated disk so it starts reminding me about itself. But the paint comes off pretty good except for sanded spots.
