Re: Compression 110/105/90?
So compression is rings or reeds, most likely? Right? I'm not much on boat motors, but on other 2 strokes this seems fair. Unless, of coarse you fry a piston. And pistons not fried. Reeds are slammed shut, and look like new. So, it is most likely a ring, or gaulded cylinder wall. But the piston should fail, before a cylinder wall. I hope. My question is, if its rings, is a motor this old worth fixing? I'm on the fence, thinking about just buying a newer motor. But I've had a few of these older ones, and when they run right, they seem to be good motors. Sounds like your a mechanic, what is your opinion? I bet you've seen a few of these. Thanks
