Just had my outboard winterized hope all was done correct, changed lower lube, saw some water then the lube was green, ran antifreeze into unit and oil in cylinders. My compression was 135 , 137, 135, 137 are those good numbers ?
u68423, Those are very good numbers. The proximity of the numbers together is the telling of the tale. Say goodnight to your motor. Grab the flywheel and turn it over one or two turns each month. Keeps the water pump from taking a set. nevjb
everything looks good exept the water that came out when you changed the gear oil, you should reseal the gear box before it gets damaged good luck bret<br /><br />If you need further assistance please email me @ forcepower01@yahoo.com.
