1960 Starflite
- Jun 23, 2011
- 387
I'm back ! Told you so ! I now have the engine rewired, carbs & fuel pump rebuilt. Going to drop the lower unit to change impeller since I know it's been over 10 years of sitting (only used three times in ten years). The engine is on a stand and I want to check the compression while the lower unit is off. It has a Type III ignition system and I have not hooked any wires up to the switch box or distributor yet. Anyone see a problem cranking the engine while in this condition?
Also, anyone know the weight of this engine compared to my 1963, 650 that is on my 24ft pontoon.
Thanks, Tom on Buckeye Lake Ohio
