pro-crastinator
- Dec 12, 2013
- 453
1958 Johnson AD-12 7.5hp - craigslist rescue.
Powerhead pulled and impeller replaced with oem. needed it.
Checked torque on head - nothing loose. Cleaned out dust bunnies from carb area.
Spark looked good. Tightened transon clamps on iboats forum designed motor "holder" (heavy and stable)
Surrounded bottom end in a bucket of water, put fuel in mityvac vessel and pressurized it with hand pump, fuel line to carb.
Pulled cord - and on third pull, it ran. It ran nicely and smoothed out in short order after fuel mix jets were adjusted.
Was not impressed with water volume coming out of exhaust but head stayed "comfortably warm" - so ok.
SHut her down and pulled spark plugs, screwed in compression gauge. The kind with threads and an O ring to seal.
Readings were 35 and 40. No way.
Motor ran like a swiss watch ( a smokey swiss watch)
When the power head was off, I looked at pistons thru exh port and it looked cleaner and relitavely scratch free.
All rings were intact and floating (not siezed in piston groove)
What am I doing wrong?
