COMPRESSION check
rogerrush
I have read the posts about compression check i have 1 question . In the posts and in the manuals it saids to crank the engine over a few times . should I crank it over 3-4 time or until the compression gage reading stop increasing??I did a compression time by reading the posts my motor my be shot I cranked it about 3 times each cylinder and only got about 60 psi.
jaxnjil
Re: COMPRESSION check
thats right. make sure you use the same # of crankes per cylinder, 3 or 4..remove all the plugs and have throttle wide open
tashasdaddy
go back and try it till it stops going up on all of them.
