I have bought an Ocena Pro 175 1994-model that previously has been under water (over ten years ago). The previous owner says that he has used it several years after that, but it has not been used the last three years.
I have not been able to start the motor, and have started with changing the starter (had corroded..) and overhauling the bendix drive (had fastened...), and was then able to test the compression.
I have to replace the optical timer wheel before trying to start it - had to take off the flywheel covers too get the bendix off. The optical timer wheel was impossible to get off without destroying it - corrosion...
The motor does not look bad from the outside, please see attached picture.
The compression is as follows (cold testing - 48 F utside);
Left side from the top
Cylinder 1 - 81
Cylinder 2 - 90
Cylinder 3 - 90
Right side from the top
Cylinder 4 - 78 (First time it showed 69, but after several testings, it was 78)
Cylinder 5 - 95
Cylinder 6- 80
Does anyone have any diagnosis or recommendations?
Cylinder 1 - 81
Cylinder 2 - 90
Cylinder 3 - 90
Cylinder 5 - 95
Cylinder 6- 80
