Compression for 72 9.5hp johnson
trita306
What should the compression be around for a 72 johnson? I know they run a little lower than expected but I am curious what is acceptable.
HighTrim
Re: Compression for 72 9.5hp johnson
As you know, they are low compression motors. You wont be getting any 100 psi plus readings. Depends on your gauge, but 70 to 95 or so? They should be even.
boobie
Have you checked yours yet and what is it ??
ultra353
On every 9.5 that I've had 60-75lbs is all I ever saw. The all ran well.
boobie
It should run on that but do a good de-carb on it once you get it running.
