compression for 93 120 rude
Lucrestyle
1993 120hp evinrude, motor runs great! i did a compression check today as a point of reference
every cylinder was 125psi is this good compression? or should it be alot higher, i only turned the engine over for 2-3 seconds twice for each cylinder.
thanks again guys
Fl_Richard
Re: compression for 93 120 rude
Equal numbers with less than 10% devaition is more important then the actual number. I'd say for a 93 looper that's good.
Lucrestyle
Thanks for your advice, is there any recommendations to maintaining this engine / creating better performance?
would new spark plug wires be a good idea?
a new set of spark plugs? the ones in it work fine.
some kind of engine carbon cleaner type shizzle made by rude/john that will clean her up?
have any recommendations to keeping this engine in tip top shape please post and again thanks alot for your reply!
tashasdaddy
a decarb with seafoam and then the continued use of seafoam as additive to the fuel. see engine freq asked questions.
