Hi fellas,89 225 jonno,just honed and all new rings,I heard that you should not have any more than 15 psi variation between cylinders which I now do not have since overhaul but the compressin in all cylinders is still only a little under 100 psi.I would hve thought it higher after the work done is this ok for this motor or should it be higher.The mechanic said these motors are known to be a relatively low compression motor.
