imported_scott_b
- Jul 15, 2003
- 1
Cylinder 6 is not getting any compression after testing. <br /><br />While running the engine in the water things seem normal, but then at random times the RPM's will dramatically fall really low. The engine never dies but i might go from 5k rpm to under 1k. I have to pull back to nuetral, then give it throttle again and things will seem normal for awhile, but then the same thing occurs. Sometimes, even before i pull back to nuetral it seems the engine returns to the rpm's it was at before the slowdown.<br /><br />Any ideas of what might be causing this would be appreciated.
