what is the compression on a 130 johnson
S subsailorssn Cadet Joined Aug 1, 2009 Messages 6 Aug 6, 2009 #1 what is the compression on a 130 johnson
kenmyfam Supreme Mariner Joined Aug 10, 2006 Messages 14,398 Aug 6, 2009 #2 Re: compression lbs. You should really post year and as many details as you can. Generally Over 100lb and all equal within 10% Compression testers vary so if you get a low reading with one tester try another before thinking the worst.
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Aug 7, 2009 #3 Re: compression lbs. agree!!!! read this >>> http://forums.iboats.com/showthread.php?t=299680
