Found some water in the engine oil with little if any in the cylinders noticeable. Compression was consistent all around with the exception of one cylinder near the riser was 25 less. Is this consistent with a leaking riser? Would a bad riser lower compression in one cylinder? A 5.7 volvo. Risers are original and 8 years old. Boat runs normal. Trying to confirm (as much as possible) it is the riser.
