Re: compression on 57 johnson 35hp
They are a tad far apart. It's recommended that they be within 10% of each other. If it was me, I would change the head gasket and do a decarb and then test it again to see what I got.
I just reread your post. If you are just trying to get it started, it should not make a diff. That's plenty of compression to start it. If it is not starting look at fuel or spark. Does it have new coils and/or a good 1/4" blue spark? Have you tried spraying 24:1 pre mix in the carb?
If it still does not run, read "Awakening an Outboard" previously posted on this forum. You'll need to search for it.
