Re: Compression on 98 Merc 5.0?
I'd expect to see 120-125 with the throttle plate open. It needs to be full open with all the plugs out to get the most accurate readings <br /><br />What you're looking for most is equality across all cylinders in the pressure readings, rather than the highest #<br /><br />Hope that helps!<br />Roger
