Compression on a 2 stroke Evinrude 150 xp?
greenesgreen
It's most likely an 80's model 2 stroke Evinrude 150 XP and i'm getting a little over 90 psi per cylinder. Is this good? If not, what could be causing the low compression?
jonesg
Re: Compression on a 2 stroke Evinrude 150 xp?
Not bad for an older engine, have you decarbed it yet?
greenesgreen
havent decarbed or gone through the motor yet, just checked the compression to see how fun of a project it was going to be. I plan on going through the carbs shortly.
