Re: compression on johnson 20
could you screw the gauge in far enough to tighen up on the rubber o-ring?...were both plugs out while you were testing?..if not and the head gasket is blown between the 2 cylinders, the cylinders may show exactly equal compression when, in fact, one is say 90 and the other 30..usually about 5 pulls will bring the reading up to as high as it's gonna read, in my experience.If that 60lb. is good for both cylinders, buy a spark gauge <open air gap type> set it at 7/16" and test the spark on both cylinders....the air gap tool is $10 or so..advance should have them....60 lbs is about as low as you want to go with compression....get the motor running, decarb it, and test the comprssion again..it should come up some..
