Compression Problem-'90 90HP Force
redrooster
What should the compression be on a 1990 90HP Force engine per cylinder? Did a compression test and mine are: 125 top, 75 middle and 125 bottom. What is my problem? Any info. would be greatly appreciated. Model Number 906A90A-C :confused:
Kajun37
Re: Compression Problem-'90 90HP Force
looks like your #2 Cyl is blown...
roscoe
Welcome redrooster.<br /><br />125 is good.<br />75 is bad. :( <br /><br />Hopefully only a head gasket.<br /><br />How did the sparkplugs lok when you removed them?
roscoe
I was hoping you would say it was steam cleaned and shiny, an indication of water in the cylinder from a blown head gasket.<br /><br />re-do the compression test just to be sure.<br /><br />Then you will need to remove the head to inspect for damage.
redrooster
I took off head and motor is junk. middle piston blow a ring off. other 2 are scared to bad to boreout. I need to know if i can sleeve it out.
redrooster
DOES ANYONE KNOW WHERE I CAN GET SLEEVES FOR A 1990 90HP FORCE MOTOR MODEL#906A90A-C. THANKS FOR ALL YOUR HELP ROSCOE!!!
imported_LakeRunner
Take the head to a local bike or ATV shop if you don't have a marine shop to take it, they can usually do the job for you. If you can do it yourself, here is good site to start. web page
redrooster
lake runner hey thanks for the great idea it never even came over me to take it to a bike shop thanks. :D :D
