I recently picked up an early 80's Evinrude 185. The first thing i did before even putting it on a boat was to see if it had good compression. All were good except for #1 and it was very confusing. It will only pump up to about 30 psi on the compression stroke and drops down to zero the rest of the time. The needle never rises above 30 psi. What might cause this reading?
