I had problems getting my 3 HP started so I checked the compression and did not like what I found. Does anyone know what the compression of my motor should be?
Oh, somewhere around 80psi. But you must use the correct kind of gauge. The check valve must be where the spark gap would be on a plug. Gauges with a hose, and the check valve at the gauge end of the hose will give low readings.
